Use the following procedure to display the default values used for the SPB-PIM Gateway interface HELLO and JOIN PRUNE intervals unless specifically configured on the individual interface.
- Click SPB-PIM-GW.
- Click the Globals tab.
Globals field descriptions
Use the data in the following table to use the Globals tab.
| Name | Description |
| HelloInterval | Displays the PIM HELLO transmission interval. |
| JoinPruneInterval | Displays the PIM JOIN PRUNE transmission interval. |
