Perform this procedure to configure the optional parameters on existing SPB-PIM Gateway interfaces.
- Click SPB-PIM-GW.
- Click the Interfaces tab.
- In the row for the interfaces, double-click the HelloInterval box, and then type the hello interval in seconds.
- In the row for the interfaces, double-click the JoinPruneInterval box, and then type the join prune interval in seconds.
Interfaces field descriptions
Use the data in the following table to use the Interfaces tab.
| Name | Description |
| IfIndex | Shows the interface index. |
| OperState | Shows the operational state of the interface. |
| AddressType | Shows the address type of the interface. |
| Address | Shows the address assigned to the interface. |
| AddressMask | Shows the address mask associated with the interface address. |
| HelloInterval | Configures the PIM HELLO transmission interval. The default is 30 seconds. |
| JoinPruneInterval | Configures the PIM JOIN PRUNE transmission interval. The default is 60 seconds. |
