View the port egress CoS queue statistics. The system displays the statistics of the forwarded packets and bytes, and the dropped packets and bytes.
If you disable rate limiting on queue 6, bandwidth is shared based on the weights from queues 0 through 6. Based on equal weights assigned for queues 4 through 6, equal amounts of traffic egress queues 4 through 6. Queue 6 therefore appears to provide much lower throughput than 50% of port bandwidth.
Variable definitions
Use the data in the following table to use the show qos cosq-stats interface <PT_PORT> command.
| Variable | Value |
| <PT_PORT> | PT indicates the slot number; PORT indicates the port number. |
The following table describes the column headings in the command output for show qos cosq-stats interface <PT_PORT>.
The Variables can differ depending on your hardware platform.
| Variable | Value |
| Cos | Indicates the Cos queue. |
| Out Packets | Indicates the out packets for the Cos queue. |
| Accepted Packets | Indicates the accepted packets for the Cos queue. |
| Out Bytes | Indicates the out bytes for the Cos queue. |
| Accepted Bytes | Indicates the accepted bytes for the Cos queue. |
| Drop Packets | Indicates the drop packets for the Cos queue. |
| Drop Bytes | Indicates the drop bytes for the Cos queue. |
