You can modify the egress mappings to change traffic priorities. However, as a best practice, use the default mappings.
Variable definitions
Use the data in the following table to use the qos egressmap command.
| Variable | Value |
| 1p <0-6> <0-7> | Maps the QoS level to IEEE 802.1p bit. Each QoS level has a default IEEE 1P value:
 default qos egressmap 1p |
| ds <0-7> WORD<1-6> | Maps the QoS level to DS byte. You can specify the DSCP in either hexadecimal, binary, or decimal format. To use the default configuration, use the default option in the command: default qos egressmap ds |
