Use this procedure to enable Dynamic Nickname Assignment and specify a nickname allocation range.
You must disable Dynamic Nickname Assignment before you can change the nickname allocation range.
- Select SPBM.
- Select the Globals tab.
- To enable the Nick-name server, select enable in the NicknameServerEnable field.
- In the NicknameServerRange field, select the nickname server allocation range or in NicknameServerPrefix, type a prefix.
Use the data in the following table to use the Globals tab.
| Name | Description |
| GlobalEnable | Enables or disables SPBM globally. The default is disabled. To ensure proper cleanup of MAC tables after you disable SPBM, save the configuration, and then reboot the switch. |
| GlobalEtherType | Specifies the global ethertype value as 0x8100 or 0x88a8. The default value is 0x8100. |
| NicknameServerEnable Note:
                                     Exception: not supported on VSP 8600 Series or XA1400 Series. | Enables or disables the nickname server. The default is disabled. |
| NicknameDynamicAllocationStatus Note:
                                     Exception: not supported on VSP 8600 Series or XA1400 Series. | Displays the Dynamic Nickname Allocation service operational status. This value is read-only. |
| NicknameServerRange Note:
                                     Exception: not supported on VSP 8600 Series or XA1400 Series. | Specifies the nickname allocation range for Dynamic Nickname Assignment. Select none to use the range 0.00.00-0.0F.FF. The default is rangeA (A.00.00 to A.FF.FF). |
| NicknameServerPrefix Note:
                                     Exception: not supported on VSP 8600 Series or XA1400 Series. | Specifies the nickname server allocation prefix. x.xx.xx uses the form X.X0.00 from 0.00.00 to F.F0.00. A group, X.X0.00 to X.XF.FF, can provide up to 4,096 nicknames. The default nickname allocation range is A.00.00-A.FF.FF. |
