Use the following procedure to configure an IS-IS manual area.
- Click IS-IS.
- Click the Manual Area tab.
- Click Insert.
- Specify an Area Address in the AreaAddr field, and click Insert.
Manual Area field descriptions
Use the data in the following table to use the Manual Area tab.
| Name | Description |
| AreaAddr | Specifies the IS-IS manual area. Valid value is 1-13 bytes in the format <xx.xxxx.xxxx...xxxx>. Only one manual area is supported. Use the same manual area across the entire SPBM cloud. For IS-IS to operate, you must configure at least one manual area. |
