Use the following procedure to change the Connectivity Association (CA) to which a port is associated.
Ensure that the new CA is created at the global level. For information about configuring a CA, see Configure a Connectivity Association.
Change the CA to which a port is associated:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#interface gigabit 1/2 Switch:1(config-if)#no macsec enable Switch:1(config-if)#macsec connectivity-association caname12 Switch:1(config-if)#macsec enable
The following table defines parameters for the macsec command.
 Variable  |
 Value  |
 connectivity-association WORD<5–16>  |
 Specifies a connectivity-association name. Tip:
Configure the Connectivity Association key name (CKN) in multiples of 4 characters to avoid MKA interoperability issues between VOSS switches and EXOS switches. For example, Macsecma (8 chararcters) or Macsecmka123 (12 characters) are valid, but Macsec (6 characters) is not valid.  |
The following table defines parameters for the interface gigabitethernet command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Specifies the port to associate with the connectivity association (CA). Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
