Perform this procedure to view MACsec status.
MACsec status
MACsec encryption status
MACsec encryption cipher suite, if supported on your hardware platform
The associated Connectivity Association (CA) name
If you do not specify a port number, the information on all MACsec capable interfaces is displayed.
enable
show macsec status {slot/port[/sub-port] [-slot/port[/sub-port]] [,...]}
show macsec
Slot and port information can differ depending on hardware platform. For more information about specific hardware, see your hardware documentation.
The switch does not support replay protect.
Configuration of a MACsec cipher suite is not supported on all hardware platforms. If you do not see it in your switch output, it is not supported. For more information on the hardware restrictions, see your hardware documentation.
View MACsec status:
Switch:1#show macsec status
                               MACSEC Port Status
         MACSEC     Encryption  Replay      Replay       Encryption       Cipher     CA       MKA-Profile
PortId   Status     Status     Protect     Protect W'dow   Offset         Suite      Name     Name
1/1      enabled    disabled   disabled      --             none          AES-128    SMLTCONN mkapro1
1/2      disabled   disabled   disabled      --             none          AES-128    Nil      --
1/3      disabled   disabled   disabled      --             none          AES-128    Nil      --
1/4      disabled   disabled   disabled      --             none          AES-128    Nil      --
1/5      disabled   disabled   disabled      --             none          AES-128    Nil      --
1/6      disabled   disabled   disabled      --             none          AES-128    Nil      --
1/7      disabled   disabled   disabled      --             none          AES-128    Nil      --
1/8      disabled   disabled   disabled      --             none          AES-128    Nil      --
1/9      disabled   disabled   disabled      --             none          AES-128    Nil      --
1/10     disabled   disabled   disabled      --             none          AES-128    Nil      --
1/11     disabled   disabled   disabled      --             none          AES-128    Nil      --
1/12     disabled   disabled   disabled      --             none          AES-128    Nil      --
1/13     disabled   disabled   disabled      --             none          AES-128    Nil      --
--More-- (q = quit)
      View MACsec status on port 1/1:
Switch:1>show macsec status 1/1
                               MACSEC Port Status
1/1      enabled    disabled   disabled      --             none          AES-128    SMLTCONN mkaprof1
      Display all MACsec information:
                     MACSEC Connectivity Associations Info
  Connectivity                Connectivity                 AN_Mode /      Port
Association Name          Association Key Hash            TxKeyParity     Members
caname33              d4433e901bae92d0cc472706f66cfc18      4AN / odd
All 1 out of 1 Total Num of Macsec connectivity associates displayed
                               MACSEC Port Status
1/1      disabled   disabled   disabled      --             none          AES-128     Nil
1/3      enabled    enabled    disabled      --        ipv4Offset(30)     AES-256    caname33
1/4      enabled    enabled    disabled      --        ipv4Offset(30)     AES-128    caname34
--More-- (q = quit)
