Display information about BGP peer groups.
The following table defines parameters for the show ip bgp peer-group command.
| Variable | Value |
| vrf WORD<1–16> | Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
| vrfids WORD<0–512> | Specifies a range of VRFs by ID number (the ID ranges from 0–512). |
| WORD<0–1536> | Specifies the name of the peer group (the string length ranges from 0–1536 characters). |
