Display information about BGP redistributed routes.
The following table defines parameters for the show ip bgp redistributed-routes command.
| Variable | Value |
| <prefix/len> | Shows paths with this prefix. The prefix is the IP address and exact mask length (must be an integer value from 0–32). |
| vrf WORD<1–16> | Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
| vrfids WORD<0–255> | Specifies a range of VRFs by ID number (the ID ranges from 0–255). |
Job aid
Use the data in the following table to understand the show ip bgp redistributed-routes command output.
| Field | Description |
| SRC-VRF | Indicates the redistribution source VRF instance. |
| SRC | Indicates the redistribution source: RIP, Local, Static, or OSPF. |
| MET | Indicates the metric value. |
| MET-TYPE | Indicates the redistribution metric type. |
| ENABLE | Indicates whether the redistribution policy is enabled (T) true or disabled (F) false. |
| RPOLICY | The route policy currently assigned to the redistribution. |
