- You must enable VRRP on a brouter port or VLAN.
You can manage and configure VRRP parameters for the routing interface.
Interface field descriptions
Use the data in the following table to use the Interface tab.
| Name | Description |
| IfIndex | Specifies the index value that uniquely identifies the interface to which this entry is applicable. |
| VrId | Specifies a number that uniquely identifies a virtual router on a VRRP router. The virtual router acts as the default router for one or more assigned addresses (1 to 255). |
| IpAddr | Specifies the assigned IP addresses that a virtual router is responsible for backing up. |
| VirtualMacAddr | Specifies the MAC address of the virtual router interface. |
| State | Specifies the state of the virtual router interface:
| Control | Specifies whether VRRP is enabled or disabled for the port (or VLAN). The default is enabled. |
| Priority | Specifies the priority value used by this VRRP router. Set a value from 1 to 255, where 255 is reserved for the router that owns the IP addresses associated with the virtual router. The default is 100. |
| AdvertisementInterval | Specifies the time interval (in seconds) between sending advertisement messages. The range is 1 to 255 seconds with a default of 1 second. Only the master router sends advertisements. The default is 1. |
| MasterIpAddr | Specifies the IP address of the physical interface of the master virtual router that forwards packets sent to the virtual IP addresses associated with the virtual router. |
| VirtualRouterUpTime | Specifies the time interval (in hundredths of a second) since the virtual router was initialized. |
| Action | Lists options to override the delay timer manually and force preemption:
| HoldDownTimer | Configures the amount of time (in seconds) to wait before preempting the current VRRP master. |
| HoldDownState | Indicates the hold-down state of this VRRP interface. If the hold-down timer is operational, this variable is set to active; otherwise, this variable is set to dormant. |
| HoldDownTimeRemaining | Indicates the amount of time (in seconds) left before the HoldDownTimer expires. |
| CriticalIpAddr | Configures the critical IP address for VRRP. This command specifies an IP interface on the local router, which is configured so that a change
                                    in its state causes a role switch in the virtual router (for
                                    example, from master to backup) in case the interface stops responding. Note:
                                         In this context, local implies an address from the same VRF as the IP interface where VRRP is being configured. |
| CriticalIpAddrEnable | Configures the IP interface on the local router to enable or disable the backup. The default is disabled. |
| BackUpMaster | Enables the backup VRRP system traffic forwarding. The default is disabled. |
| BackUpMasterState | Indicates whether the backup VRRP system traffic forwarding is enabled or disabled. The default is disabled. |
| FasterAdvInterval | Configures the Fast Advertisement Interval between sending VRRP advertisement messages. The interval is between 200 and 1000 milliseconds, and you must enter the same value on all participating routers. The default is 200. You must enter the values in multiples of 200 milliseconds. |
| FasterAdvIntervalEnable | Enables or disables the Fast Advertisement Interval. When disabled, the regular advertisement interval is used. The default is disable. |
