Perform this procedure to configure VRRP on a V3 interface on either a brouter port or a VLAN.
- Assign an IPv4 address to the interface
- Enable routing globally
- Do not configure RSMLT on the VLAN
- In the navigation pane, expand the following folders: .
- Click VRRP.
- Click the V3 Interface tab.
- Click Insert.
- Beside the IfIndex field, click Port or VLAN.
- Select a port or VLAN.
- Click OK.
- Type the virtual router ID.
- Type the primary IP address.
- Type the advertisement interval.
- Click Insert.
Interface field descriptions
Use the data in the following table to use the Interface tab.
| Name | Description |
| IfIndex | Shows the index value that uniquely identifies the interface to which this entry applies. |
| InetAddrType | Specifies the source network INET Address Type. |
| VrId | Specifies a number that uniquely identifies a virtual router on a VRRP router. |
| PrimaryIpAddr | Specifies the virtual address assigned to the VRRP. |
| VirtualMacAddr | Specifies the MAC address of the virtual router interface. |
| State | Shows the state of the virtual router interface. The possible states are
| Control | Displays whether VRRP is enabled or disabled for the port or VLAN. |
| Priority | Specifies the priority value used by this VRRP router. The value 255 is reserved for the router that owns the IP addresses associated with the virtual router. The default is 100. |
| AdvInterval | Specifies the time interval, in seconds, between sending advertisement messages. The default is 1 second. |
| MasterIpAddr | Specifies the IP address of the physical interface of the Master's virtual router. |
| UpTime | Indicates the time interval since this virtual router exited the INIT state. |
| CriticalIpAddr | Indicates the IP address of the interface that is critical to VRRP. If that IP interface is down, the VRRP state will transition to Backup, even if it has higher priority. |
| CriticalIpAddrEnabled | Enables or disables the use of critical IP. When disabled, the VRRP ignores the availability of the address configured as critical IP. This address must be a local address. The default is disabled. |
| BackUpMaster | Uses the backup VRRP switch for traffic forwarding. This option reduces the traffic on the vIST. The default is disabled. |
| BackUpMasterState | Indicates if the Backup-Master is operational up. If the switch is in Master state but the Backup-Master is enabled, then the BACKUP MASTER STATE will be down. |
| FasterAdvIntervalEnabled | Enables or disables the fast advertisement interval. When disabled, the regular advertisement interval is used. The default is disable. |
| FasterAdvInterval | Configures the interval between VRRP advertisement messages. The default is 200. Enter the values in multiples of 200 milliseconds. |
| PreemptMode | Issued to preempt the existing router. If a new router is added to the network with its priority higher than the existing routers, then the new router becomes the master. The default is enabled. |
| Action | Lists options to override the hold-down timer manually and force preemption:
 This parameter applies only if the holddown timer is active. |
| HoldDownTimer | Configures the amount of time, in seconds, to wait before preempting the current VRRP master. The default is 0. |
| HoldDownTimeRemaining | Indicates the amount of time, in seconds, left before the HoldDownTimer expires. |
| MasterAdvInterval | On the VRRPv3 master, the master advertisement interval is same as the advertisement interval. On the VRRPv3 Backup, the master advertisement interval is set to the Advertisement configured on the Master (received in the packet). |
