Use the show ip pim active-rp command to display information about the active rendezvous point (RP) for all groups or a specific group. If you do not specify an IP address, you receive information about the active RP for all the running multicast groups on the switch. The syntax for this command is as follows.
show ip pim active-rp [group {A.B.C.D}]
The following table shows the field descriptions for this command.
Field |
Description |
GRPADDR |
Shows the IP address of the multicast group. |
RP-ADDR |
Shows the IP address of the RP router. This address must be one of the local PIM-SM enabled interfaces. |
RP-PRIORITY |
Shows the priority of the RP. |
Display information about the active rendezvous points:
Pim Grp->RP Active RP Table - GlobalRouter
GRPADDR RP-ADDR RP-PRIORITY
239.0.0.1 20.0.0.90 0
239.0.0.2 20.0.0.90 0
239.0.0.3 20.0.0.90 0
239.0.0.4 20.0.0.90 0
239.0.0.5 20.0.0.90 0
239.255.255.250 20.0.0.90 0
