Use the show ip pim bsr command to display information about the bootstrap router (BSR) for this PIM-SM domain. The syntax for this command is as follows.
show ip pim bsr
The following table shows the field descriptions for this command.
Field |
Description |
Current BSR address |
Shows the IP address of the current BSR for the local PIM domain. |
Current BSR priority |
Shows the priority of the current BSR. The C-BSR with the highest BSR priority and address (referred to as the preferred BSR) is elected as the BSR for the domain. |
Current BSR HaskMask |
Shows the mask used in the hash function to map a group to one of the C-RPs from the RP set. The hash-mask allows a small number of consecutive groups (for example, 4) to always hash to the same RP. |
Current BSR Fragment |
Shows a randomly generated number that distinguishes fragments that belong to different bootstrap messages. Fragments that belong to the same bootstrap message carry the same fragment tag. |
Pim Boostrap Timer |
Shows the bootstrap timer. After the bootstrap timer expires, the BSR sends out bootstrap messages. |
