Use the show ipv6 pim active-rp command to display information about the active rendezvous point (RP) for all groups or a specific group. If you do not specify an IPv6 address, you receive information about the active RP for all the running multicast groups on the switch. The syntax for this command is as follows.
show ipv6 pim active-rp [group WORD<0-255>]
Switch:1(config)#show ipv6 pim active-rp
                   Pim Grp->RP Active RP Table - GlobalRouter
GRPADDR/
RP-ADDR                                         RP-PRIORITY
ff30:0:0:0:0:0:0:1
5040:0:0:0:0:1:84:1
The following table shows the field descriptions for this command.
| Field | Description |
| GRPADDR | Shows the IPv6 address of the multicast group. |
| RP-ADDR | Shows the IPv6 address of the RP router. This address can be one of the local PIM-SM enabled interfaces or a gobal IPv6 address of the chosen RP based on hash function. |
| RP-PRIORITY | Shows the priority of the RP. |
