Use the show ipv6 pim rp-hash command to display information about the RPs selected for a multicast group. The syntax for this command is as follows.
Switch:1(config)#show ipv6 pim rp-hash
Pim RPSet - GlobalRouter
GRPADDR/GRPMASK HOLDTIME EXPTIME
RP-ADDR
ff10:0:0:0:0:0:0:0/64 0 0
5040:0:0:0:0:1:84:1
ff30:0:0:0:0:0:0:0/64 0 0
5040:0:0:0:0:1:84:1
ff30:1:0:0:0:0:0:0/32 0 0
5174:0:0:0:0:1:84:1
Total RP Set Entries Displayed: 3/3
The following table shows the field descriptions for this command.
Field |
Description |
GRPADDRESS |
Shows the IPv6 address of the multicast group. When combined with the group mask, it identifies the prefix that the local router uses to advertise itself as a C-RP router. |
GRPMASK |
Shows the address mask of the multicast group. When combined with the group address, it identifies the prefix that the local router uses to advertise itself as a C-RP router. |
RP-ADDR |
Shows the IPv6 address of the static RP. |
HOLDTIME |
Shows the hold time of the static RP. The value is 0. |
EXPTIME |
Shows the minimum time remaining before the static RP is down. The value is 0. |
