Perform this procedure to configure EAP or change the authentication status on Extreme Integrated Application Hosting (IAH) ports. IAH ports are force-authorized by default and are not authenticated by the RADIUS server. You can change this setting so that the IAH ports stay unauthorized.
EAPOL Field Descriptions
Use data in the following table to use the EAPOL tab.
Name |
Description |
PortCapabilities |
Shows the capabilities of the Port Access Entity (PAE) associated with the Extreme Integrated Application Hosting (IAH) port. This parameter indicates whether Authenticator functionality, supplicant functionality, both, or neither, is supported by the PAE of the IAH port. The following capabilities are supported by the PAE of the IAH port:
PortVirtualPortsEnable |
Shows the status of the Virtual Ports function for the IAH port. |
PortCurrentVirtualPorts |
Shows the current number of virtual ports running on the IAH port. |
PortAuthenticatorEnable |
Shows the status of the Authenticator function in the PAE. |
PortSupplicantEnable |
Shows the Supplicant function in the PAE. |
AllowNonEapHost |
Enables network access to hosts that do not participate in 802.1X authentication. The default is disabled. |
Status |
Specifies the authentication status for the IAH port.
The default is forceAuthorized. |
MultiHostMaxClients |
Specifies the maximum number of supplicants authenticated on the IAH port. |
GuestVlanId |
Specifies the VLAN ID to be used as a Guest. Access to unauthenticated hosts connected to the IAH port is provided through this VLAN. 0 indicates that Guest VLAN is not enabled. |
FailOpenVlanId |
Specifies the Fail Open VLAN ID for the specific IAH port. If RADIUS server is not reachable on the switch, then all new devices are allowed access to the configured Fail Open VLAN ID. 0 indicates that Fail Open VLAN ID is not enabled. |
NonEapMaxClients |
Specifies the maximum number of NEAP authentication MAC addresses allowed on the specific IAH port. 0 indicates that NEAP authentication is disabled. |
EAPMaxClients |
Specifies the maximum number of EAP authentication MAC addresses allowed on the specific IAH port. 0 indicates that EAP authentication is disabled. |
MultiHostSingleAuthEnabled |
Enables the functionality for network access to the unauthenticated devices only after an EAP or NEAP client is successfully authenticated on the IAH port. The VLAN ID to which the devices are allowed access is the authenticated client's VLAN. The default is disabled. |
PortGuestIsid
Note: Exception: Not supported on VSP 8600
Series or XA1400
Series.
Specifies the I-SID to be used as a Guest I-SID. Access to unauthenticated hosts connected to the IAH port is provided through this I-SID. 0 indicates that Guest I-SID is not enabled for this port. |
FailOpenIsid
Series or XA1400
Series.
Specifies the Fail Open I-SID for the IAH port. If the switch declares the RADIUS servers unreachable, then all new devices are allowed access into the configured Fail Open I-SID. 0 indicates that Fail Open I-SID is not enabled for this port. |
FlexUniStatus
supported on VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Displays the current Flex-UNI status for this IAH port. |
AdminTrafficControl
Series or XA1400
Series.
Configures the Administrative Traffic Control.
The default is inOut.
OperTrafficControl Note: Exception: Not supported on VSP 8600
Series or XA1400
Series.
Displays the current Operational Traffic Control status. |
LldpAuthEnabled Note: Exception: Not supported on VSP 4450
Series, VSP 8600
Series, or
XA1400
Series.
Enables LLDP authentication for this IAH port. The default is disabled. |
PortOrigin Note: Exception: Not supported on VSP 4450
Series, VSP 8600
Series, or
XA1400
Series.
Specifies the source of EAP configuration on the IAH port:
DynamicMHSAEnabled Note: Exception: Not supported on VSP 4450
Series, VSP 8600
Series, or
XA1400
Series.
Displays the Dynamic MHSA configuration status. |
Authenticate |
Shows the current Authenticator Port Access Entity (PAE) authenticate status. |
Authenticated |
Shows the current Authenticator Port Access Entity (PAE) authenticated status. |
Failed |
Shows the current Authenticator Port Access Entity (PAE) failure status. |
ReAuthEnabled |
Enables reauthentication of an existing supplicant based on the specified reauthentication time interval. The default is disabled. |
QuietPeriod |
Specifies the time interval (in seconds) between authentication failure and start of authentication. |
ReauthPeriod |
Specifies the time interval (in seconds) between successive reauthentications. The default is 3600 (1 hour). |
RetryMax |
Specifies the maximum Extensible Authentication Protocol (EAP) requests sent to the supplicant before timing out the session. The default is 2. |
RetryCount |
Specifies the maximum number of retries attempted. |
