Configure EAP or change the authentication status on one or more ports.
Ports are force-authorized by default. Force-authorized ports are always authorized and are not authenticated by the RADIUS server. You can change this setting so that the ports are always unauthorized.
EAPoL Field Descriptions
Use the data in the following table to use the EAPoL tab.
Name |
Description |
PortCapabilities |
Displays the capabilities of the Port Access Entity (PAE) associated with the port. This parameter indicates whether Authenticator functionality, supplicant functionality, both, or neither, is supported by the PAE of the port. The following capabilities are supported by the PAE of the port:
PortVirtualPortsEnable |
Displays the status of the Virtual Ports function for the real port as True or False. |
PortCurrentVirtualPorts |
Displays the current number of virtual ports running in the port |
PortAuthenticatorEnable |
Displays the status of the Authenticator function in the Port Access Entity (PAE) as True or False. |
PortSupplicantEnable |
Displays the Supplicant function in the Port Access Entity (PAE) as True or False. |
AllowNonEapHost |
Enables network access to hosts that do not participate in 802.1X authentication. The default is disabled. |
Status |
Configures the authentication status for this port. The default is forceAuthorized.
MultiHostMaxClients |
Specifies the value representing the maximum number of supplicants allowed to get authenticated on the port. |
GuestVlanId |
Specifies the VLAN to be used as a Guest VLAN. Access to unauthenticated hosts connected to this port is provided through this VLAN. 0 indicates that Guest VLAN is not enabled for this port. |
FailOpenVlanId |
Specifies the Fail Open VLAN ID for this port. If the switch declares the RADIUS servers unreachable, then all new devices are allowed access into the configured Fail Open VLAN. 0 indicates that Fail Open VLAN is not enabled for this port. |
NonEapMaxClients |
Specifies the maximum number of NEAP authentication MAC addresses allowed on this port. Zero indicates that NEAP authentication is disabled for this port. |
EAPMaxClients |
Specifies the maximum number of EAP authentication MAC addresses allowed on this port. Zero indicates that EAP authentication is disabled for this port |
MultiHostSingleAuthEnabled |
Indicates that the unauthenticated devices can access the network only after an EAP or NEAP client is successfully authenticated on the port. The VLAN to which the devices are allowed access is the authenticated client's VLAN. The default is false. |
| PortGuestIsid Note: Exception: Not
supported on VSP 8600
Series or XA1400
Series.
Specifies the I-SID to be used as a Guest I-SID. Access to unauthenticated hosts connected to this port is provided through this I-SID. 0 indicates that Guest I-SID is not enabled for this port. |
| FailOpenIsid Note: Exception: Not
Series or XA1400
Series.
Specifies the Fail Open I-SID for this port. If the switch declares the RADIUS servers unreachable, then all new devices are allowed access into the configured Fail Open I-SID. 0 indicates that Fail Open I-SID is not enabled for this port. |
| FlexUniStatus Note: Exception: Not
supported on VSP 4450
Series, VSP 8600
Series, or XA1400
Series.
Displays the current Flex-UNI status for this port. |
| AdminTrafficControl Note: Exception: Not
Series or XA1400
Series.
Configures the Administrative Traffic Control. The default is
inOut.
| OperTrafficControl Note: Exception: Not
Series or XA1400
Series.
Displays the current Operational Traffic Control status. |
| LldpAuthEnabled Note: Exception: Not
Series, VSP 8600
Series, or XA1400
Series.
Enables LLDP authentication for this port. The default is disabled. |
PortOrigin Note:
Exception: not supported on VSP 8600 Series and XA1400 Series. |
Specifies the source of EAP configuration on the port:
| DynamicMHSAEnabled Note: Exception: Not
Series, VSP 8600
Series, or XA1400
Series.
Displays the Dynamic MHSA configuration status. |
Authenticator configuration |
Displays the current Authenticator Port Access Entity (PAE) state. The states are:
ReAuthEnabled |
Reauthenticates an existing supplicant at the time interval specified in ReAuthPeriod. The default is disabled. |
QuietPeriod |
Configures the time interval (in seconds) between authentication failure and the start of a new authentication. |
ReAuthPeriod |
Reauthenticates an existing supplicant at the time interval specified in ReAuthPeriod. Configures the time interval (in seconds) between successive reauthentications. The default is 3600 (1 hour). |
RetryMax |
Specifies the maximum Extensible Authentication Protocol (EAP) requests sent to the supplicant before timing out the session. The default is 2. |
RetryCount |
Specifies the maximum number of retries attempted. |
