Viewing RSTP Port Statistics
View RSTP statistics on ports to manage network performance.
Slot and port information can differ depending on hardware platform.
show spanning-tree rstp port statistics [{slot/port[/sub-port][-slot/port[/sub-port]][,...]}]
View RSTP statistics:
Switch:1#show spanning-tree rstp port statistics
Port Number                       : 4/1
Number of Fwd Transitions         : 0
Rx RST BPDUs Count                : 0
Rx Config BPDU Count              : 0
Rx TCN BPDU Count                 : 0
Tx RST BPDUs Count                : 0
Tx Config BPDU Count              : 0
Tx TCN BPDU Count                 : 0
Invalid RST BPDUs Rx Count        : 0
Invalid Config BPDU Rx Count      : 0
Invalid TCN BPDU Rx Count         : 0
Protocol Migration Count          : 0
Port Number                       : 4/2
--More-- (q = quit)
Use the data in the following table to use the show spanning-tree rstp port statistics command.
 Variable  |
 Value  |
 {slot/port[/sub-port][-slot/port[/sub-port]][,...]}  |
 Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port.  |
Job Aid
The following table describes output for the show spanning-tree rstp port statistics command.
 Parameter  |
 Description  |
 RxRstBpduCount  |
 The number of RSTP BPDUs received on this port.  |
 RxConfigBpduCount  |
 The number of configuration BPDUs received on this port.  |
 RxTcnBpduCount  |
 The number of TCN BPDUs received on this port.  |
 TxRstBpduCount  |
 The number of RSTP BPDUs transmitted by this port.  |
 TxConfigBpduCount  |
 The number of Config BPDUs transmitted by this port.  |
 TxTcnBpduCount  |
 The number of TCN BPDUs transmitted by this port.  |
 InvalidRstBpduRxCount  |
 The number of invalid RSTP BPDUs received on this port. A trap is generated on the occurrence of this event.  |
 InvalidConfigBpduRx Count  |
 The number of invalid configuration BPDUs received on this port. A trap is generated on the occurrence of this event.  |
 InvalidTcnBpduRxCount  |
 The number of invalid TCN BPDUs received on this port. A trap is generated on the occurrence of this event.  |
 ProtocolMigrationCount  |
 The number of times this port migrated from one STP protocol version to another. The relevant protocols are STP-Compatible and RSTP. A trap is generated on the occurrence of this event.  |
