Viewing RSTP Statistics
View Rapid Spanning Tree Protocol statistics to manage network performance.
show spanning-tree rstp statistics
Job Aid
The following table describes output for the show spanning-tree rstp statistics command.
 Parameter  |
 Description  |
 RSTP Up Count  |
 The number of times RSTP port has been enabled. A Trap is generated on the occurence of this event.  |
 RSTP Down Count  |
 The number of times RSTP port has been disabled. A Trap is generated on the occurence of this event.  |
 Count of Root Bridge Changes  |
 The number of times this Bridge has detected a Root Bridge change for Common Spanning Tree context.  |
 STP Time since Topology change  |
 The time (in hundredths of a second) since the "TcWhile" Timer for any port in this Bridge was non zero for this spanning tree instance.  |
 Total number of topology changes  |
 The number of times that there have been atleast one non zero "TcWhile" Timer on this Bridge for this spanning tree instance.  |
