Enable SSH globally.
Switch:1>enable Switch:1#configure terminal
Enable SSH rekeying globally:
Switch:1(config)#ssh rekey enable
The following table defines parameters for the ssh rekey command.
| Variable | Value |
| enable | Enables SSH rekey globally. |
