Perform this procedure to uninstall a configured virtual service.
If a virtual machine is running, it is stopped, and then the service directory is uninstalled.
You must disable the virtual service before you uninstall it.
Switch:1>enable Switch:1#virtual-service tpvm uninstall
Use data in the following table to use the virtual-service command.
| Variable | Value |
| WORD<1-80> | Specifies the virtual service name. |
| uninstall | Uninstalls the specified virtual service name. |
