Perform this procedure to display the virtual service configuration on the switch.
show virtual-service config [WORD<1-80>]
Name displayed in the following show output is the Virtual Machine (VM) image name and not the version of the application within the VM. You can see the version of the application by logging in to the console. For more information, see Access a Virtual Service Console.
Switch:1>show virtual-service config tpvm
                            Virtual Services Config
Virtual Service :tpvm
Additional Disk Assigned:
   Name           Size(GB)
   vdb               2
  VPort Information:
  Name            Vlan      Connect Type    Insight Port    NIC Type
  InsightPort                   vtd             1/s1
  eth0                          ovs             1/s1         VIRTIO
Management Status :         Enabled
