Perform this procedure to view inventory attributes for LLDP-MED on specific ports.
- Click Port MED.
- Click the Neighbor Inventory tab.
Neighbor Inventory Field Descriptions
| Name | Description |
| TimeMark | Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
| LocalPortNum | Specifies the port on which the remote LLDP-MED information is received. |
| Index | Specifies the particular connection instance that is unique to the remote LLDP-MED. |
| HardwareRev | Specifies the current hardware revision of the LLDP-MED. |
| FirmwareRev | Specifies the current firmware revision of the LLDP-MED. |
| SoftwareRev | Specifies the current software revision of the LLDP-MED. |
| SerialNum | Specifies the current serial number of the LLDP-MED. |
| MfgName | Specifies the manufacturer of the LLDP-MED. |
| ModelName | Specifies the model name of the LLDP-MED. |
| AssetID | Specifies the asset tracking identifier for the LLDP-MED. |
