Perform this procedure to view PoE Powered Device (PD) information for remote LLDP-MED on specific ports.
- Click Port MED.
- Click the Neighbor PoE PD tab.
Neighbor PoE PD Field Descriptions
| Name | Description |
| TimeMark | Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
| LocalPortNum | Specifies the port on which the remote LLDP-MED information is received. |
| Index | Specifies the particular connection instance that is unique to the remote LLDP-MED. |
| PDPowerReq | Specifies the value of the power required by a PD LLDP-MED connected remotely to the port. |
| PDPowerSource | Specifies the power source being utilized by the PD LLDP-MED.
| PDPowerPriority | Specifies the priority of the PD LLDP-MED connected remotely to the port, for more information, see RFC 3621.
