This procedure only applies to VSP 8600 Series.
After you create the Management Instance, you can add an IP address to it, and then configure route redistribution to advertise reachability of the Management Instance to the rest of the network.
                    Ensure the IP address you plan to assign is not in use by an existing VLAN or CLIP IP subnet configured on the switch.
MgmtAddress Field Descriptions
Use the data in the following table to use the MgmtAddress tab.
| Name | Description |
| InstanceId | Shows a value that identifies the Management Instance type associated with this entry. |
| IpAddress | Specifies the IPv4 management address. |
| IpMask | Specifies the subnet mask of the IPv4 management address. |
| Ipv6Address | Specifies the IPv6 management address. Each Management Instance supports a single IPv6 management address for use by management applications. |
| Ipv6PrefixLength | Specifies the prefix length of the IPv6 management address. It is /128 for a loopback interface. |
| Ipv6LinkLocalAddr | Shows the automatically generated link local address. |
| InterfaceName | Shows the interface name. |
