This procedure only applies to VSP 8600 Series.
You must create a Management Instance to gain access to specific management applications.
The Management Instance supports different management interface types. When you create the Management Instance, you specify the interface type and the switch automatically creates the appropriate instance ID for that type.
In a Layer 3 routing or Fabric deployment, use a management CLIP.
Each Management Instance supports a single IPv4 and IPv6 (global scope) management address for use by management applications.
MgmtInterface field descriptions
Use the data in the following table to use the MgmtInterface tab.
| Name | Description |
| InstanceId | Shows a value that identifies the Management Instance type associated with this entry. |
| InterfaceType | Indicates the interface type. |
| VrfName | Specifies the VRF name to associate with the management CLIP . |
| State | Indicates if the interface is enabled for this instance. The default is disabled. |
| InterfaceMacAddr | Shows the MAC address for the interface. |
| InterfaceName | Shows the interface name. |
