Use the show ip pim interface command to display information about the PIM-SM interface configuration on the switch. The syntax of this command is as follows.
show ip pim interface [gigabitethernet {slot/port[/sub-port][-slot/port[/sub-port]][,...]}|vlan <1-4059>]
The following table shows the field descriptions for this command if you do not use optional parameters.
| Field | Description |
| IF | Indicates the slot and port number or VLAN ID of the interface where PIM is enabled. |
| ADDR | Shows the IP address of the PIM interface. |
| MASK | Shows the network mask for the IP address of the PIM interface. |
| MODE | Indicates the configured mode of this interface. The valid modes are SSM and Sparse. |
| DR | Shows the designated router (DR) for this interface. |
| HLINT | Specifies how long to wait (in seconds) before the PIM router sends out the next hello message to neighboring switches. The default hello interval is 30 seconds. |
| JPINT | Specifies how long to wait (in seconds) before the PIM router sends out the next join or prune message to its upstream neighbors. The default join and prune interval is 60 seconds. |
| CBSPR | Specifies the preference for this local interface to become a C-BSR. The C-BSR with the highest BSR priority and address the preferred BSR. The default is –1, which indicates that the current interface is not a C-BSR. |
| OPSTAT | Indicates the status of PIM on this interface: up or down. |
| INTF TYPE | Indicates whether the PIM interface is active or passive. |
The following table shows the field descriptions for this command if you use optional parameters.
| VLAN-ID or PORT-NUM | Indicates the slot and port number or VLAN ID of the interface where PIM is enabled. |
| PIM ENABLE | Indicates the administrative status of PIM. |
| HELLOINT | Specifies how long to wait (in seconds) before the PIM router sends out the next hello message to neighboring switches. The default hello interval is 30 seconds. |
| CBSRPREF | Specifies the preference for this local interface to become a C-BSR. The C-BSR with the highest BSR priority and address the preferred BSR. The default is –1, which indicates that the current interface is not a C-BSR. |
Switch:1(config)#show ip pim interface
                          Pim Interface - GlobalRouter
IF        ADDR            MASK            MODE       DR              HLINT  JPIN        T  CBSPR          OPSTAT INTF TYPE
Port1/4   10.1.1.1        255.255.255.0   ssm        10.1.1.1        30     60        -1 (disabled)  up     active
Clip1     111.10.10.10    255.255.255.255 ssm        111.10.10.10    30     60        11 (enabled) up     passive
Vlan300   21.0.0.206      255.255.255.0   ssm        21.0.0.206      30     60        -1  (disabled)  up     active
Vlan400   41.0.0.206      255.255.255.0   ssm        41.0.0.206      30     60        -1  (disabled)  up     active
Vlan500   31.0.0.206      255.255.255.0   ssm        31.0.0.206      30     60        -1  (disabled)  up     active
Vlan700   62.0.0.206      255.255.255.0   ssm        62.0.0.206      30     60        -1  (disabled)  up     active
Vlan701   62.0.1.206      255.255.255.0   ssm        62.0.1.206      30     60        -1  (disabled)  up     active
Vlan702   62.0.2.206      255.255.255.0   ssm        62.0.2.206      30     60        -1  (disabled)  up     active
Vlan703   62.0.3.206      255.255.255.0   ssm        62.0.3.206      30     60        -1  (disabled)  up     active
