Use the show ip pim rp-candidate command to display information about the candidate rendezvous points for the PIM-SM domain.The syntax for this command is as follows.
The following table shows the field descriptions for this command.
Field |
Description |
GRPADDR |
Displays the IP address of the multicast group. When combined with the group mask, this value identifies the prefix that the local router uses to advertise itself as a C-RP router. |
GRPMASK |
Displays the address mask of the multicast group. When combined with the group address, this value identifies the prefix that the local router uses to advertise itself as a C-RP router. |
RPADDR |
Displays the IP address of the C-RP router. This address must be one of the local PIM-SM enabled interfaces. |
