Verify that SSH services are enabled on the switch and display SSH configuration information to ensure that the SSH parameters are properly configured.
Display global system SSH information:
Switch:1>show ssh global
Total Active Sessions     : 0
        version                   : v2only
        port                      : 22
        max-sessions              : 4
        timeout                   : 60
        action rsa-host key       : rsa-hostkeysize 2048
        action dsa-host key       : dsa-hostkeysize 1024
        rsa-auth                  : false
        dsa-auth                  : true
        pass-auth                 : true
        keyboard-interactive-auth : false
        sftp enable               : true
        enable                    : true
        authentication-type       : aead-aes-128-gcm-ssh aead-aes-256-gcm-ssh hmac-sha1 hmac-sha2-256
        encryption-type           : 3des-cbc aead-aes-128-gcm-ssh aead-aes-256-gcm-ssh aes128-cbc aes128-ctr
                                    aes192-cbc aes192-ctr aes256-cbc aes256-ctr blowfish-cbc rijndael128-cbc
                                    rijndael192-cbc
        key-exchange-method       : diffie-hellman-group1-sha1 diffie-hellman-group14-sha1
The following table defines parameters for theshow ssh command.
| Variable | Value |
| global | Display global system SSH information. |
| session | Display the current session SSH information. |
