Configure the SA limit to limit the number of SA messages from an MSDP peer that the router saves in the SA cache. The default value is 6,144 messages.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp sa—limit 21.0.0.2 6100
Variable definitions
The following table defines parameters for the ip msdp sa-limit command.
 Variable  |
 Value  |
 {A.B.C.D}  |
 Specifies the MSDP peer IP address.  |
 <0-6144>  |
 Specifies the maximum number of SA messages to keep in SA cache.  |
