Configure Message Digest (MD) 5 authentication to secure control messages on the TCP connection between MSDP peers.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp md5–authentication 21.0.0.2 enable
Switch:1(config)#ip msdp password peer 21.0.0.2 helloworld
Variable definitions
The following table defines parameters for the ip msdp command.
 Variable  |
 Value  |
 {A.B.C.D}  |
 Specifies the MSDP peer IP address.  |
 WORD<1-80>  |
 Specifies the MD5 authentication password.  |
