You can modify the ingress mappings to change traffic priorities. However, as a best practice, use the default mappings.
Variable definitions
Use the data in the following table to use the qos ingressmap command.
| Variable | Value |
| 1p <0-7> <0-6> | Maps the IEEE 802.1p bit to QoS level. Each QoS level has a default IEEE 1P value:
 default qos ingressmap 1p |
| ds <0-63> <0-6> | Maps the DS byte to QoS level. The system reserves level 7 for Network Control. To use the default configuration, use the default option in the command: default qos ingressmap ds |
