Use the following procedure to display IS-IS areas.
show isis manual-area
Switch# show isis manual-area
                            ISIS Manual Area Address
AREA ADDRESS
c0.2000.0000.00
Job aid
The following table describes the fields in the output for the show isis manual-area command.
| Parameter | Description |
| AREA ADDRESS | Shows the manual areas defined. There can only be one area. Use the same manual area across the entire SPBM cloud. The manual area can be from 1-13 bytes in length. |
