Configure a peer description to add descriptive text to an MSDP peer for easy identification of a peer.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ip msdp peer 21.0.0.2 primary
Variable definitions
The following table defines parameters for the ip msdp description command.
 Variable  |
 Value  |
 {A.B.C.D}  |
 Specifies the MSDP peer IP address.  |
 WORD<1-255>  |
 Specifies a descriptive text to a MSDP peer in the range of 1-255 characters. To include spaces in the peer description, enclose the text string in quotation marks.  |
