View DvR domain redistribution information on a Controller or a Leaf node.
You can view DvR domain redistribution information only on a DvR Controller.
An error message displays if you attempt to view this information on a DvR Leaf node.
Ensure that you enable DvR globally on the node.
View DvR domain redistribution information on a Controller:
Switch:1#show dvr redistribute
                             DVR Redistribute List - GlobalRouter
SOURCE MET MTYPE      ENABLE RPOLICY
STAT   1   External   TRUE  -
View DvR domain redistribution information for a particular VRF.
Switch:1#show dvr redistribute vrf vrf1
                               DVR Redistribute List - VRF vrf1
STAT   20000 External   TRUE  -
LOC    10000 Internal   TRUE  -
Variable definitions
Use the data in the following table to use the show dvr redistribute command.
| Variable | Definitions |
| vrf WORD<1-16> | Specifies the VRF name. |
| vrfids WORD<0-512> | Specifies the VRF ID of the VRF. |
Job aid
Use the data in the following table to use the show dvr redistribute command output.
| Field | Description |
| SOURCE | Specifies the source of the DvR route redistribution. |
| MET | Specifies the DvR route redistribution metric. The range is 0 to 65535. |
| MTYPE | Specifies the DvR route redistribution metric type. |
| ENABLE | Specifies whether DvR route redistribution is enabled on the VRF instance. |
| RPOLICY | Specifies the route policy for DvR route redistribution. |
