View VRFs corresponding to Layer 3 (routed) VSN I-SIDs on either a Controller or a Leaf node.
Ensure that you enable DvR globally on the node.
View Layer 3 VSN information on a DvR Controller:
Switch:1#show dvr l3vsn
                         DVR L3VSN
VRF ID            L3VSN ISID    VRF NAME   INJECT-DEFAULT-ROUTE-DISABLE
1                 55500         vrf600     Disabled
2                 55501         vrf601     Disabled
3                 55502         vrf602     Disabled
4                 55503         vrf603     Disabled
4 out of 4 Total Num of DVR L3VSN displayed
View Layer 3 VSN information on a DvR Leaf node:
Switch2:1#show dvr l3vsn
                         DVR L3VSN
1                 55500         vrf600
2                 55501         vrf601
3                 55502         vrf602
3 out of 3 Total Num of DVR L3VSN displayed
Variable definitions
Use the data in the following table to use the show dvr l3vsn command.
| Variable | Value |
| l3isid <0-16777215> | Specifies the Layer 3 VSN I-SID. The range is 0 to 16777215. |
| vrf WORD<1-16> | Specifies the VRF name of the VRF corresponding to the Layer 3 VSN I-SID. |
| vrfids WORD<0-512> | Specifies the VRF ID of the VRF. |
Job aid
Use the data in the following table to use the show dvr l3vsn command output on a DvR Controller.
| Field | Description |
| VRF ID | Specifies the VRF ID of the VRF corresponding to the Layer 3 VSN I-SID. |
| L3VSN ISID | Specifies the Layer 3 VSN I-SID. |
| VRF NAME | Specifies the VRF name of the VRF corresponding to the Layer 3 VSN I-SID. |
| INJECT-DEFAULT-ROUTE-DISABLE | Specifies whether injection of default routes is disabled. |
Use the data in the following table to use the show dvr l3vsn command output on a DvR Leaf node.
