Viewing VRRP information
Display VRRP port or VLAN information to verify your configuration. Show VRRP information by IPv6 address or virtual router ID. If you enter a virtual router ID or an IPv6 address when you view VRRP information, the information applies only to that virtual router ID or for that interface.
Switch:1>show ipv6 vrrp address
                            VRRP Info - GlobalRouter
VRID P/V   IP                              MAC                STATE    CONTROL
12   1/1   fe80:0:0:0:0:0:0:1234           00:00:5e:00:02:0c  Init     Disabled
VRID P/V   MASTER                          PRIO  ADV  UP TIME
12   1/1   0:0:0:0:0:0:0:0                 100   1    0 day(s), 00:00:00
VRID P/V   CRITICAL IP                              CRITICAL IP   ACCEPT
                                                    ENABLED       MODE
12   1/1   0:0:0:0:0:0:0:0                          No            disable
VRID P/V   BACKUP   BACKUP-MASTER   FAST (ENABLED)  ACTION   HLD     REM
           MASTER   STATE           ADV                      DWN
12   1/1   disable  down            400  (YES)       none     30       0
VRID P/V   GLOBAL ADDRESS
12   1/1   1111::2222/64
Flags Legend:
HLD DWN: Configured hold-down timer value, REM: REMaining hold-down timer value
--More-- (q = quit)
                                 Switch:1#show ipv6 vrrp interface verbose
                          Vlan Vrrp for IPv6 Extended
VLAN VRF              VRRP                           MASTER
ID   NAME             ID   STATE   CONTROL PRIORITY  IPADDR
40   GlobalRouter     1    init    disable 100       0:0:0:0:0:0:0:0
40   GlobalRouter     2    init    disable 100       0:0:0:0:0:0:0:0
All 2 Vlan Vrrp Extended Entries out of 18 Total Num of Vrrp displayed
VLAN VRF              VRRP HOLDDWN ACTION  CRITICAL   CRITICAL
ID   NAME             ID           TIME    IP ENABLE  IPADDR
40   GlobalRouter     1    0       none    disable    0:0:0:0:0:0:0:0
40   GlobalRouter     2    0       none    disable    0:0:0:0:0:0:0:0
VLAN VRF              VRRP BACKUP  BACKUP  ADVERTISE  FAST ADV   FAST ADV   MASTER ADV PREEMPT
ID   NAME             ID   MASTER  MASTER  INTERVAL   INTERVAL   ENABLE     INTERVAL   MODE
                                   STATE   (s)        (ms)                  (ms)
40   GlobalRouter     1    disable down    1          200        disable    1000       enable
40   GlobalRouter     2    disable down    1          200        disable    1000       enable
                          Port Vrrp for IPv6 Extended
PORT  VRF              VRRP                           MASTER
NUM   NAME             ID   STATE   CONTROL PRIORITY  IPADDR
1/23  GlobalRouter     1    init    disable 100       0:0:0:0:0:0:0:0
1/23  GlobalRouter     2    init    disable 100       0:0:0:0:0:0:0:0
All 2 Port Vrrp Extended Entries out of 18 Total Num of Vrrp displayed
PORT  VRF              VRRP HOLDDWN ACTION  CRITICAL   CRITICAL
NUM   NAME             ID           TIME    IP ENABLE  IPADDR
1/23  GlobalRouter     1    0       none    disable    0:0:0:0:0:0:0:0
1/23  GlobalRouter     2    0       none    disable    0:0:0:0:0:0:0:0
PORT  VRF              VRRP BACKUP  BACKUP  ADVERTISE  FAST ADV   FAST ADV   MASTER ADV PREEMPT
NUM   NAME             ID   MASTER  MASTER  INTERVAL   INTERVAL   ENABLE     INTERVAL   MODE
                                    STATE   (s)        (ms)                  (ms)
1/23  GlobalRouter     1    disable down    1          200        disable    1000       enable
1/23  GlobalRouter     2    disable down    1          200        disable    1000       enable
           Variable definitions
Use the data in the following table to use the show ipv6 vrrp commands.
| Variable | Value |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
| link-local WORD<0–127> | Displays information by link-local IPv6 address. |
| verbose | Displays extended information. |
| vlan [<1-4059> ] | Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. |
| vrid <1–255> | Displays information by virtual router ID. |
| vrf WORD<1–16> | Specifies the VRF name. |
| vrfids WORD<0–512> | Specifies the VRF ID. |
