Configure VRRP to provide fast failover of a default router for IPv6 LAN hosts, in order to create a VRRP instance.
- Assign an IPv6 address to the interface.
- Enable routing globally.
- Do not configure RSMLT on the VLAN.
- You must specify a link-local address to associate with the virtual router.
VRRP supports a virtual IPv6 address shared between two or more routers that connect the common subnet to the enterprise network.
VRRP for IPv6 provides a faster switchover to an alternate default router than is possible using the ND protocol.
Perform this procedure to also configure the additional addresses for which the virtual router acts as a backup.
Associate a link-local address with the virtual router ID 12:
Switch:1(config-if)#ipv6 vrrp address 12 link-local fe80::1234
Associate a global address with the virtual router ID 12
Swith:1(config-if)#ipv6 vrrp address 12 global 3333::1234/64
Enable VRRP for the interface:
Switch:1(config-if)#ipv6 vrrp 12 enable
Variable definitions
Use the data in the following table to use the ipv6 vrrp address command.
| Variable | Value |
| <1-255> | Specifies the virtual router ID. The virtual router acts as the default router for one or more associated addresses. |
| enable | Enables IPv6 VRRP. The default is disabled. |
| global WORD <0–255> | Specifies a global IPv6 address and mask to associate with the virtual router. |
| link-local WORD <0-127> | Specifies a link-local IPv6 address to associate with the virtual router. |
Use the data in the following table to use the interface command.
| Variable | Value |
| <1-4059> | Specifies the VLAN ID in the range of 1 to 4059. By default, VLAN IDs 1 to 4059 are configurable and the system reserves VLAN IDs 4060 to 4094 for internal use. On switches that support the vrf-scaling and spbm-config-mode boot configuration flags, if you enable these flags, the system also reserves VLAN IDs 3500 to 3998. VLAN ID 1 is the default VLAN and you cannot create or delete VLAN ID 1. |
| {slot/port[/sub-port][-slot/port[/sub-port]][,...]} | Identifies the slot and port in one of the following formats: a single slot and port (slot/port), a range of slots and ports (slot/port-slot/port), or a series of slots and ports (slot/port,slot/port,slot/port). If the platform supports channelization and the port is channelized, you must also specify the sub-port in the format slot/port/sub-port. |
