Use this procedure to display MLD snooping interface parameters.
Switch:1#show ipv6 mld interface
                         Mld Interface - GlobalRouter
IF   STATUS VERS  OPER VERS QUERIER                                 Wrong Query JOINS MODE
P6/3 inact  2     2         2001:0db8:3c4d:0015:0000:0000:1a2f:1aaa   0      		0     pim
V666 inact  2     2         2001:0db8:3c4d:0015:0000:0000:1a2f:1bbb   0 	     	0     pim
Switch:1#show ipv6 mld interface vlan 10
                                  Vlan IPv6 Mld
VLAN QUERY QUERY ROBUST VERSION LAST  SNOOP  SSM     DYNAMIC
ID   INTVL MAX                  LIST  ENABLE SNOOP   DOWNGRADE
           RESP                 QUERY        ENABLE
10   125   10    2      1       1     false  false   enabled
Switch(config)#show ipv6 mld interface gigabitethernet 1/11
                                 Port IPv6 MLD
PORT QUERY QUERY ROBUST VERSION LAST  DYNAMIC
NUM  INTVL MAX                  LIST  DOWNGRADE
           RESP                 QUERY
1/11 125   10    2      1       1     enabled
1 out of 1 entries displayed
Variable definitions
The following table describes the variables for the show ipv6 mld interface command.
 Variable  |
 Description  |
 vlan <1-4059>  |
 Displays MLD snooping information for the configured VLANs.  |
 gigabitEthernet {slot/port[/sub-port]}  |
 Displays MLD snooping information on a specific interface.  |
Job Aid
The following table describes the column headings in the command output for show ipv6 mld interface.
 Variable  |
 Description  |
 VLAN ID  |
 Indicates the VLAN ID of the physical interface.  |
 PORT NUM  |
 Indicates the port number of the physical interface.  |
 QUERY INTVL  |
 Indicates the query interval, the frequency at which IPv6 MLD snooping host-query packets are transmitted on this interface.  |
 QUERY MAX RESP  |
 Indicates the maximum query response time advertised in IPv6 MLD snooping queries on this interface.  |
 ROBUST  |
 Indicates the robustness value.  |
 VERSION  |
 Indicates the version.  |
 LAST LIST QUERY  |
 Indicates the last listener query interval. The last listener query interval is the maximum response delay inserted into group-specific queries sent in response to leave group messages, and it is also the amount of time between group-specific query messages.  |
 SNOOP ENABLE  |
 Indicates if snooping is enabled.  |
 SSM SNOOP ENABLE  |
 Indicates if ssm-snooping is enabled.  |
 DYNAMIC DOWNGRADE ENABLE  |
 Enables dynamic downgrade of the MLD version when older version query message is received.  |
