Use this procedure to display MLD snooping tracing information.
Switch:1#show ipv6 mld snoop-trace
              Mld Snoop Trace - GlobalRouter
GROUP/
SOURCE                 IN     IN   OUT    OUT      TYPE
ADDRESS                VLAN   PORT VLAN   PORT
ff10:0:0:0:0:0:0:1/    10     2/15 10     3/16     ACCESS
5051:0:0:0:0:1:84:51
Job Aid
The following table describes the column headings in the command output for show ipv6 mld snoop-trace.
 Variable  |
 Description  |
 GROUP ADDRESS  |
 Specifies the IP multicast address of the group traversing the router  |
 SOURCE ADDRESS  |
 Specifies the IP source address of the multicast group address.  |
 IN VLAN  |
 Specfies the ingress VLAN ID for the multicast source.  |
 IN PORT  |
 Specifies the ingress port for the multicast group.  |
 OUT VLAN  |
 Specifies the egress VLAN ID for the multicast group.  |
 OUT PORT  |
 Specifies the egress port of the multicast group.  |
 TYPE  |
 Specifies the port type on which the snoop entry is learnt.  |
