Use the following procedure to graph IS-IS interface sending control packet statistics.
 - Click IS-IS.
 - Click the Interfaces tab.
 - Select an existing interface.
 - Click the Graph button.
 - Click the Interface Receiving Control Packets tab.
Interface Receiving Control Packets Field Descriptions
The following table describes the fields in the Interface Receiving Control Packets tab.
 Name  |
 Description  |
 Hello  |
 Indicates the number of IS-IS Hello PDUs seen in this direction at this level. Point-to-Point IIH PDUs are counted at the lowest enabled level: at L1 on L1 or L1L2 circuits, and at L2 otherwise.  |
 LSP  |
 Indicates the number of IS-IS link-state packet (LSP) frames seen in this direction at this level.  |
 CSNP  |
 Indicates the number of IS-IS Complete Sequence Number Packet (CSNP) frames seen in this direction at this level.  |
 PSNP  |
 Indicates the number of IS-IS Partial Sequence Number Packets (PSNPs) seen in this direction at this level.  |
 AbsoluteValue  |
 Displays the counter value.  |
 Cumulative  |
 Displays the total value since you opened the Stats tab.  |
 Average/Sec  |
 Displays the average value for each second.  |
 Minimum/Sec  |
 Displays the minimum value for each second.  |
 Maximum/Sec  |
 Displays the maximum value for each second.  |
 Last Val/Sec  |
 Displays the last value for each second.  |
