Displaying File Statistics
Display the amount of memory used and available for onboard flash memory, as well as the number of files.
- Click File System.
- Click the Storage Usage tab.
Storage Usage Field Descriptions
Use the data in the following table to use the Storage Usage tab.
Name |
Description |
IntflashBytesUsed |
Specifies the number of bytes used in internal flash memory. |
IntflashBytesFree |
Specifies the number of bytes available for use in internal flash memory. |
IntflashNumFiles |
Specifies the number of files in internal flash memory. |
UsbBytesUsed |
Specifies the number of bytes used in USB device. |
UsbBytesFree |
Specifies the number of bytes available for use in USB device. |
UsbNumFiles |
Specifies the number of files in USB device. |
