Use the following procedure to graph IS-IS interface sending control packet statistics.
- Click IS-IS.
- Click the Interfaces tab.
- Select an existing interface.
- Click the Graph button.
- Click the Interface Receiving Control Packets tab.
Interface Receiving Control Packets field descriptions
The following table describes the fields in the Interface Receiving Control Packets tab.
| Name | Description |
| Hello | Indicates the number of IS-IS Hello PDUs seen in this direction at this level. Point-to-Point IIH PDUs are counted at the lowest enabled level: at L1 on L1 or L1L2 circuits, and at L2 otherwise. |
| LSP | Indicates the number of IS-IS link-state packet (LSP) frames seen in this direction at this level. |
| CSNP | Indicates the number of IS-IS Complete Sequence Number Packet (CSNP) frames seen in this direction at this level. |
| PSNP | Indicates the number of IS-IS Partial Sequence Number Packets (PSNPs) seen in this direction at this level. |
| AbsoluteValue | Displays the counter value. |
| Cumulative | Displays the total value since you opened the Stats tab. |
| Average/Sec | Displays the average value for each second. |
| Minimum/Sec | Displays the minimum value for each second. |
| Maximum/Sec | Displays the maximum value for each second. |
| Last Val/Sec | Displays the last value for each second. |
