DvR backbone members are either DvR Controllers or non-DvR BEBs that receive redistributed host routes from all other DvR Controllers in the SPB network.
Ensure that DvR is enabled globally on the node.
View all DvR backbone members:
Switch:1#show dvr backbone-members
DVR BB Members
System Name Nick-Name Nodal MAC Role Domain Id
DVR-D2-C1-40 0.82.40 00:00:82:84:40:00 NON-DVR-BEB 2
Ctrl-2:8200:122 0.81.22 00:bb:00:00:81:22 Controller 2
2 out of 2 Total Num of DVR Backbone Members displayed
View backbone members that are DvR controllers:
Switch:1#show dvr backbone-members controller
DVR BB Members (Domain ID: 255)
1 out of 2 Total Num of DVR Backbone Members displayed
View backbone members that are non-DvR BEBs:
Switch:1#show dvr backbone-members non-dvr-beb
DVR BB Members
Variable definitions
Use the data in the following table to use the show dvr backbone-members command.
Variable |
Value |
controller |
Specifies backbone members that are DvR Controllers. |
non-dvr-beb |
Specifies backbone members that are non-DvR BEBs. |
Job aid
Use the data in the following table to use the show dvr backbone-members command output.
Field |
Description |
System Name |
Specifies the system name of the DvR backbone member. |
Nick-Name |
Specifies the nick name of the DvR backbone member. |
Nodal MAC |
Specifies the nodal MAC address of the DvR backbone member. |
Role |
Specifies the role of the DvR backbone member. |
Domain Id |
Specifies the domain ID of the backbone member. |
