Display summarized information about BGP.
The following example shows partial output for the show ip bgp summary command.
Switch:1>show ip bgp summary vrf vrf1
BGP Summary - VRF vrf1
BGP version - 4
local-as - 22610
Identifier - 27.82.217.1
Decision state - Idle
The total number of routes is 0
BGP NEIGHBOR INFO :
NEIGHBOR RMTAS STATE HLDTM KPALV HLDCFG KPCFG WGHT CONRTY ADVINT UPTime
192.0.2.1 22620 Active 0 0 180 60 100 120 5 0 day(s), 07:25:09
Total bgp neighbors: 1
BGP CONFEDERATION INFO :
confederation identifier 0
confederation peer as
--More-- (q = quit)
The following table defines parameters for the show ip bgp summary command.
Variable |
Value |
vrf WORD<1–16> |
Specifies a VRF instance by name. |
vrfids WORD<0–512> |
Specifies a range of VRFs by ID number. |
Job aid
Use the data in the following table to understand the show ip bgp summary command output.
Field |
Description |
BGP version |
Specifies the version of BGP that runs on the router. |
local-as |
Specifies the local autonomous system number. |
Identifier |
Specifies the BGP identifier. |
Decision state |
Specifies the BGP process state. |
NEIGHBOR |
Specifies the IP address of the remote peer. |
RMTAS |
Specifies the AS number of the remote peer. |
STATE |
Specifies the peer operating state: Idle, Accept, Connect, Open, Open-sent, and Established. |
HLDTM |
Specifies the negotiated hold time timer. |
KPALV |
Specifies the keep alive timer. |
HLDCFG |
Specifies the configured hold time timer. |
KPCFG |
Specifies the configured keep alive timer. |
WGHT |
Specifies the weight value assigned to the peer. |
CONRTY |
Specifies the retry timer. |
ADVINT |
Specifies the advertisement interval. |
UPTime |
Specifies how long (in seconds) this peer has been in the established state, or how long since this peer was last in the established state. It is set to zero when a new peer is configured or when the router is booted. If the peer never reaches the established state, the value remains zero. |
