Display information about BGPv6 redistributed routes.
The following table defines parameters for the show bgp ipv6 redistributed-routes command.
| Variable | Value |
| vrf | Specifies a VRF instance by name (the string length ranges from 1–16 characters). |
| vrfids | Specifies a range of VRFs by ID number (the ID ranges from 0–255). |
