Viewing MSTP Statistics
Display MSTP statistics to see MSTP related bridge-level statistics.
show spanning-tree mstp statistics
Switch:1#show spanning-tree mstp statistics
                             MSTP Bridge Statistics
Mstp UP Count                   : 1
Mstp Down Count                 : 0
Region Config Change Count      : 12
Time since topology change      : 8 day(s), 02H:54M:33S
Topology change count           : 10
New Root Bridge Count           : 25
Job Aid
The following table describes the output for the show spanning-tree mstp statistics command.
 Parameter  |
 Description  |
 MSTP Up Count  |
 The number of times the MSTP port has been enabled. A Trap is generated on the occurrence of this event.  |
 MSTP Down Count  |
 The number of times the MSTP port has been disabled. A Trap is generated on the occurrence of this event.  |
 Region Config Change Count  |
 The number of times the switch detects a Region Configuration Identifier Change. The switch generates a trap on the occurrence of this event.  |
 Time since topology change  |
 The time (in hundredths of a second) since the TcWhile Timer for any port in this Bridge was non-zero for Common Spanning Tree context.  |
 Topology change count  |
 The count of at least one non zero TcWhile timers on this Bridge for Common Spanning Tree context.  |
 New Root Bridge Count  |
 The number of times this Bridge has detected a Root Bridge change for Common Spanning Tree context. A Trap is generated on the occurrence of this event.  |
