Use this procedure to display information about the MLD snooping configuration for the switch.
Switch:1#show ipv6 mld snooping
================================================================================        Mld Snooping - GlobalRouter
IFINDEX SNOOP   SSM     ACTIVE           MROUTER
        ENABLE  SNOOP   MROUTER          EXPIRATION
                ENABLE  PORTS            TIME
V666		False	False	NONE						 0
1 out of 1 entries displayed
Job Aid
The following table describes the column headings in the command output for show ipv6 mld snooping.
 Variable  |
 Description  |
 IFINDEX  |
 Identifies the index of the physical interface.  |
 SNOOP ENABLE  |
 Identifies whether snoop is enabled (true) or disabled (false).  |
 SSM SNOOP ENABLE  |
 Identifies whether SSM snoop is enabled (true) or disabled (false).  |
 ACTIVE MROUTER PORTS  |
 Displays all dynamic (querier port) and static mrouter ports that are active on the interface.  |
 MROUTER EXPIRATION TIME  |
 Specifies the time remaining before the multicast router is aged out on this interface. If the switch does not receive queries before this time expires, it flushes out all group memberships known to the VLAN. The Query Max Response Interval (obtained from the queries received) is used as the timer resolution.  |
