Viewing RIP Statistics
Use statistics to help you monitor Routing Information Protocol (RIP) performance. You can also use statistics in troubleshooting procedures.
 - Click RIP.
 - Click the Status tab.
Status Field Descriptions
Use the data in the following table to use the Status tab.
 Name  |
 Description  |
 Address  |
 The IP address of the router interface.  |
 RcvBadPackets  |
 The number of RIP response packets received by the RIP process that were subsequently discarded for any reason (examples: a version 0 packet or an unknown command type).  |
 RcvBadRoutes  |
 The number of routes, in valid RIP packets, that were ignored for any reason (examples: unknown address family or invalid metric).  |
 SentUpdates  |
 The number of triggered RIP updates actually sent on this interface. This field explicitly does not include full updates sent containing new information.  |
